Nigel-YZ1
- Somewhere else... maybe soon.
My Beemer has them too. But I thought they were dangerous - every time I switched them on they flashed on and off. Can't risk it if there's dodgy wiring in there.
Brilliant. But you forgot that Mercedes too have stopped including them.Indicators are completely unnecessary. Even BMW stopped fitting them to their cars some time ago.
And dont forget Audi too.Brilliant. But you forgot that Mercedes too have stopped including them.
I saw a BMW this morning that not only had indicators, was actually using themIndicators are completely unnecessary. Even BMW stopped fitting them to their cars some time ago.
If fitted to gloves, then they are a duplication of effort: you would have to stick your hand out to use them which you would be doing anyway.
They would also add bulk and I can't envisage a simple solution.
If they operate automatically from some sort of sensor then you have the problem of them activating at the wrong time or not at all.
If operated by a switch you would need two mounted on either side of the handlebar (to operate the opposite indicator); or one mounted in each glove (perhaps by pressing the thumb and forefinger together) which brings us back to the problem of inopportune use.
With brakes and gears being hand-operated we already have plenty to think of.
Furthermore, gloves are a very personal choice so a whole range of gloves would need to produced or some sort of kit which could be added to an existing pair of gloves; either option would be prohibitively expensive for a relatively small market.
