ThePainInSpain
- Malaga, Spain
Left the house at 9:00 this morning hoping for a pleasant couple of hours on the bike. The sun was up, the sky was a clear cloudless blue, the forecast was for a max of 25c, so aimed to be back by mid-day, before the heat (and the wind) had built too much.
Was having a few problems getting the gears to shift, which turned into the gears not shifting at all. So back home to try to sort it.
The cable to the rear derailleur had frayed and would not move at all.
2 choices, fix it myself or put the bike in the car and drive the 20km to Decathlon and get them to fix it.
I opted for the former, although had visions of me taking the bike, in bits, to Decathlon for them to put it back together.
Managed to work out how the shifter came to bits, and how to get the cable out. Could I get it out of the outer casing, no way. In the end I had to cut the cable to get it out.
Decided to try the LBS in the next town, about 13km away, so zipped off on the motor scooter. Having checked first what the price in Decathlon was (€3.95). Got to the LBS, €1, so bought two.
Got back home, put the bike on my Lidl's stand and had it all back together within 5 mins. I slight adjustment of the tension and it's working and shifting better than before, Went for a quick test ride........................perfik.
Can't believe how easy it was to sort.
I put on new brake blocks a couple of weeks back, I'm getting quite pleased with myself in my dotage.
