New bike so I expect some cable stretch. After 30 miles I found this minor problem........small (inner) cog on the front, when I change up to the 2nd smallest & smallest) at the back it is making noises to tell it it's not set correctly.
I 'think' I should turn the adjuster counter-clockwise which I 'think' will pull the cable........is this correct?
I can & will play around but a bit of good advice will hopefully make things easier.
Thanks
Thanks
