Which mudguards for Felt VR40
Dadam
SW Leeds
Second prototype for seat tube mount:
First prototype clamp was too small. This one works a treat. I'm thinking of recessing the nut at the bottom and using a shorter bolt to make it look less meccano-like and printing it in black. I do have some black filament but at the moment printing in black is a PITA. I mis-ordered and have a huge 3kg reel which won't fit on my printer spool so I have to wind off enough for each print.
si_c
Wirral
That's looking really good.
As an aside I was thinking it might be worthwhile replacing the front derailleur with a 105 CAM derailleur instead of the Tiagra one you have there - they interfere far less with the mudguards.
Dadam
SW Leeds
Interesting, which model, and what does CAM mean in this context? It never crossed my mind to start upgrading components on a brand new bike.
si_c
Wirral
The 105 R7000, Ultegra R8000 or newer and the GRX front derailleurs. CAM means it uses a CAM action to pull the derailleur rather than a lever approach so needs less clearance. It's not going to improve shifting, but is a nice quality of life improvement with close fitting mudguards.
I think the GRX400 is under £20 and should work with Tiagra. Make sure you follow the fitting instructions - they are a bit more fiddly than regular front derailleurs but not too bad.
Dadam
SW Leeds
Cheers. The R7000 and R8000 seem to be for 11-speed rather than 10-speed. Though I'm not sure why this matters for the front except maybe chain thickness or chain line? Some also seem to be braze-on so need for an adaptor with those.
Hmm, I'm in two minds. The idea of not having to trim the mudguard and having it all looking neater is certainly attractive but also derailleurs seem like a black art at times,
si_c
Wirral
They are but there is no difference at the front, it's all 2 speed. The R7000 is available in band-on - you may have to look it's not always available online.
I just had a look and ebay have it, but it'll be shipped from China so a little longer to get to you. eBay link.
Dadam
SW Leeds
Version 1.2 hot off the print bed
Very happy with how it's turned out.
Much neater with the recessed nut, and easier to fit too, no fiddling about with a spanner to stop the nut turning.
I was hoping to go for a long ride tomorrow, but might have to be with no front as I've got a bit of work to do on that. Should be dry though.
sevenfourate
Devotee of OCD
^^^Truly looks like it grew there and was meant to be. That’s the sign of great work !!
Dadam
SW Leeds
Thanks. It's a bit more rough and ready close up. I've only got basic CAD skills, use a free web program aimed at students, and a low-mid range printer that I haven't had that much experience using. But I was inspired by the Creo part above and I am really pleased with how that came out.
si_c
Wirral
Just a note, but my Dad needed to get a part for a roof rack and the manufacturer wanted about £40 with postage, ended up finding the CAD for the part online for a couple of quid and got it printed commercially with a more robust plastic.
Worth keeping in mind if there are issues with durability later. You've already made the CAD part, so could also make it available to others.
Dadam
SW Leeds
Found a new FD-R8000 band-on on Ebay (link), shipped from Sheffield for a really low price. First thought obviously was fake but seller has 99.8% positive feedback including for this actual item. I know chains are faked a lot but I would have thought it would be quite hard to make a convincing fake high end front mech. I'm going to take a punt.
Dadam
SW Leeds
R8000 FD is here... but, it's 34.9mm and looks like the Felt is 31.8 :cry:
In fact turns out the seat tube actually measures 32.6 and the factory fit FD clamp has a right old gap at the closure, so it might even have a 28.6 clamp.
I'm aware shimming is a thing and so I kind of thought there'd be a couple of shims in the R8000 box but nope. The 31.8mm Ultegra FDs are available online but £30-40. So should I return it and pay some more for get the proper fitment, or shim it? I have a selection of the flexible shims you get for bar fittings for lights etc but I've a feeling it should be more rigid than that. Could print something I guess.
And all because I was really odd and wanted some full length mudguards on a new bike which has mudguard mounting points!
si_c
Wirral
Shim it, you'll probably need a shim either way, I grabbed one off Amazon for a couple of quid.
Dadam
SW Leeds
Nearly done! I 3d printed a pair of shims last weekend and fitted the FD yesterday. Fit is spot on and I'm pretty happy with how it's gone on.
First set of shims just had a straight top but i did another with a scoop out to match the profile of the clamp on that side.
I did consider taking if off again and sanding it more flush but having a lip on the top makes it much easier to fit. Just put the bolt in the clamp leaving a gap and slot the shims in from the top.
Took some messing around and a lot of watching videos to get the derailleur setup right but I think it's there now.
Only just had enough cable! Annoyed as the bike came in the box with about 9" extra length coiled up and I trimmed it as I wasn't to know I'd be swapping out the mech so soon.
Very glad I went for a new FD as it looks so much better than with a slot cut in the mudguard to clear the arm.
Today I refitted the rear and adjusted and trimmed the stays (but forgot to take a photo).
I hadn't planned to do the fronts today, and was losing the light but was in the "zone" for fettling so carried on in the light from the garage door.
Front fitted with the left hand stays after judicious bending to the best angle for the mounting points.
Did the same with the right hand front stays, then cut them all to rough length and adjusted inside the garage as it was now nearly full dark. I'll trim them properly another time once I'm happy with the position.
