Banjo
Fuelled with Jelly Babies
- South Wales
Ah yes, the very ones that burned a man's house down in another active thread here on cc.
Yeh but apart from that there great.No pleasing some people.
I will let you know if it burns my house down, Anyone with half a brain does not leave those batteries unattended whilst charging,Ah yes, the very ones that burned a man's house down in another active thread here on cc.
His point was that if you have two then you have a back up, and I agree with it. I've set off on a journey and the batteries seemed fine when I switched them on but faded quickly on the journey or recently the bracket for one worked its way loose just as I went into a park so I caught it, but having two means than you have a back up. At the front you are usually aware if the front one disappears for some reason.Or you could buy one good light instead of two junk ones.
But then, a circular beam is far harder to aim onto the road properly. If mounted about a metre up, aiming 8ft ahead means either you're dazzling oncomers or you've a 45 degree beam or less, and few unapproved lights seem that constrained.I ride nights down a few unlit country roads, i have this pointed towards the ground about 8ft in front of me, Brilliant little light for the money, As for dazzling motorist those helmet lights are good for that, But then most light will dazzle motorist if they are pointing in the wrong direction.
If it's in use, it's subject to all the same external hazards as the other light and not a backup. I carry a backup light in my bag, but I check whether my main light is working by looking at it from time to time.His point was that if you have two then you have a back up, and I agree with it.
You can check but if it fails I'd rather have a light already on, it's extremely rare for me to have a light fall off, but not so rare to have forgotten to charge my light, or to have it be switched on in my pannier by accident (or chucked in without switching off which I do if I'm hurrying.)If it's in use, it's subject to all the same external hazards as the other light and not a backup. I carry a backup light in my bag, but I check whether my main light is working by looking at it from time to time.
Same here, main light in use and a Moon 500 as back up, on the bars and ready should it be needed.His point was that if you have two then you have a back up, and I agree with it. I've set off on a journey and the batteries seemed fine when I switched them on but faded quickly on the journey or recently the bracket for one worked its way loose just as I went into a park so I caught it, but having two means than you have a back up. At the front you are usually aware if the front one disappears for some reason.
HA means no single points of failure, reliable crossovers and failure detection, while disaster recovery aims to prevent, detect and correct, so having two lights in use is neither. It's just two lights in use.High availability vs disaster recovery.
All the chat about brackets and recharging and side visibility and so on are really making me happy I'm running well-designed bolted-on dynamo lights on the bike I usually ride at night. I do have battery lights on the road bike, but they're all sadly now obsolete: the closest current ones are the Cateye GVolt (NOT Volt which has a much worse lens) and Axa Greenline, if you can find them in this country.
