Drago
- Suburban Poshshire
White spirit to clean. It can be left to stand,separated and re used.
Gear oil to lube.
Gear oil to lube.
How does everyone deal with the degreaser run off? Always have a concern letting it run into the drains.
I forgot to say I switched to drip wax lube, it makes the whole process easier/cleaner.
I stopped using mucoff when found out how salty it is, I just use car shampoo. I degreased all our chains and use squirt, which is water soluble, makes chain cleaning easier
In general I've learnt to do less, wipes are great 👍
Cleaning the chain off the bike involves breaking the chain on some bikes
Our folder doesn;t which makes it much easier - I just take it off and dump it in a bowl of degreaser and leave it while I do everything else - and probably the other bike as well
but for bikes where it involves breaking the chain I prefer to use a chain cleaning gadget (blue plastic thing - Park Tools sell them)
works well - just need to make sure it is well rinsed after and re-lubed
If I'm giving it a quick clean to get the mud off then I use the hose
give it a good spray all over and under the mudguards
Then get the leaf blower and give it a good blow to get as much water off as possible - especially the chain and gears
Then a quick squirt on every link of the chain and wind the chain through all the gears
then either leave it in the sun - if there is any - or straight in the shed to be locked up
The leaft blower makes a huge difference - much less rusty bits since I started using it to dry everything
Hmm, not thought of using the leaf blower to dry the bike off. Ours is an old and rather heavy model but gotta be worth a try. I wonder if the old hot air paint stripper would work![]()
You’re not meant to drink it
A word of warning, which should be mentioned in the instructions but often isn't. Don't put your hands/fingers/other body parts into the cleaner fluid whilst it is turned on. Ultrasonic baths operate at frequencies between 20 & 40KHz and that just happens to include frequencies that can (i.e. it's not impossible) cause cavitation in the blood stream with catastrophic consequences - such as death. No matter how slim the chances of this happening might be they are still there.I just bought a six litre ultrasound cleaning machine. I have several bikes to restore and thought this would be good for chains and cassettes and bolts and stuff.
