Which cassette spacer?
uclown2002
Harrogate
The first link if you're fitting a 10 sp shimano cassette.
uclown2002
Harrogate
Shimano 8, 9 & 10 Speed Cassette Compatibility With 11 Speed Freehub
The Dura-Ace CS-9000 & Ultegra CS-6800 HG-EV 11 Speed Cassette is 1.85mm wider than a 10 speed HG cassette, therefore the freehub dimensions have been adjusted accordingly. In order to mount a CS-9000 or CS-6800 HG-EV 11 speed cassette, an 11- speed wheel must be used.
When mounting a 10 speed cassette on the new 11 speed freehub design 2 spacers are required. Firstly a 1.85mm spacer which is supplied with the wheel, secondly a 1mm spacer which is supplied with the cassette.
To run a 8 or 9 speed cassette, only the 1.85 spacer is required.
