GrumpyGregry
Here for rides.
MacB any half decent frame builder restorer will weld an extra bit of steerer tube on your forks for less than the price of a decent tyre.
no. But the weld would be stronger than the original tube!oh I know but can you imagine me being happy with that? I've already bought their replacements anyway![]()
Bottoming forks out out under compression depends on the 'spring rate'. Air isn't a linear spring. So the force required to make the spring compress a given distance should increase the more the spring is compressed. Useful glossary here
How much sag you want/need, and what your compression damping settings (both low speed and speed), and your rebound damping setting all sit neatly in the category called 'depends' or 'this is an art not a science'.
watch out to be certain the steerer tube on any donor bike is not only the right diameter/type but also of a length which is appropriate to the headtube size of the recipient bike or more expense and hassle will await you.
Anyway, being indulgent I ordered a custom frame, mainly to cater to my preferred hub gear needs and to allow for touring potential. From the test rides, and my ridiculously large spreadsheets of geometry, my custom build has ended up closest in design to a Cotic Solaris. I even specced the ability to go up to a 120mm fork though the frame is really optimised for 80-100mm....that's my just in case attitude.
How about you save £200 by getting a Ragley Piglet instead of the Soul, and then you can get the donor with Rebas and the decent wheelset? I suspect that you'll find the Soul and the Piglet remarkably similar at your level of experience.
