I usually cycle on the road but there has been a diversion so I moved over to a shared pavement as indicated by a blue sign with person and cyclist image.
The sign is located on a wide quiet part of pavement which continues over a pedestrian crossing displaying the green person and also green cyclist light = shared crossing.
However after the crossing the pavement is narrower and busier - there is no 'Cyclist dismount' sign and further up this pavement there are some blue cycle route signs.
This morning I was told by a pedestrian that I shouldn't be cycling on the pavement - common sense also tells me that this part of the pavement isn't really wide enough to be a shared path (also there are bus stops at several points) although I'd waited until it was clear and cycled around him slowly.
However legally, does this sound like a shared path still? i.e. does a shared path continue until I see a notice saying 'Cyclists Dismount'?
, thankfully it is only a 10 minute cycle or so.
