Long story short: I traced a rattle on my hybrid to the cassette being loose, and when tightening the lockring made no difference I tried adding an improvised spacer (rubber band!) and it's fine now.
A bit of googling shows this is a common problem people have when fitting a new cassette, and in my case I need the extra 1mm spacer for an 11T cassette to fit the hub. But I wasn't fitting a new cassette. I've had it for thousands of miles, and I've never taken it off once.
So how can an spacer vanish? It can't just fall off, as it's stuck between the inside edge of the hub and the cassette. Even if it broke it should still stay in place unless it completely disintegrated, shouldn't it?
I'm at a loss to explain this. Has anyone else lost a spacer in this way?
