Sam Kennedy
- Newcastle
I was reading cyclecraft, and it says to stay in primary if the traffic is light, you are going the same speed as traffic, or it is unsafe to be overtaken.
I'm not too sure when it's unsafe to be overtaken, the only times I can think of are passing parked cars to avoid the door zone, roundabouts, and junctions.
When else is it unsafe?
I'm also guessing that unless you are cycling on a busy road, you spend most of your time in primary position?
Also, what about roads that don't have much traffic, but when a car does come it is normally speeding? Is it better to stay in primary so they see you, or secondary so they don't hit you?
Those are the two things which are knocking my confidence, since I don't know when I have the right to take the lane, or where I should be on lightly trafficked(sp?) but fast roads. If I can clear these up I will be on the path alot less often
