Ed no-more-lemons
- The Burbs
After an initial inspection the 27" rear wheel appeared to have a massive flat spot on the rim and two parallel spokes had bowed right in to become loose.
Needing to get home I bumped along for a fair number of miles.
I have just released the tension in the next two spokes too the bowed pair.
Now I observe a high spot next to the old flat spot maybe 5mm and the old flat is where it should be.although a bit dented.
Quite serious I know, although I am ok with correcting lateral wobble and have read reams on spoke twisting, I am not sure what step to take next.
Tighted (quarter turns)the opposite side of the wheel from the hub or to correct the lateral wobble and to go from there?
The lateral correction should at least get me into work tomorrow, if indeed the rim is doomed anyway.
Any opinions welcomed.
