weight limits range from 95-110 kg for most manufacturers. you are over that.Do wheels themselves have weight limits?
I'm finding my rear wheel needs truing again.. I did it once myself but I was rubbish at it.
I'm taking it to LBS for them to sort it now - noticed one of the spokes you could tweak by hand - that can't be right.
I'm 18 stone odd but don't consider that to be too heavy, maybe it's just the cheap bike (Did spend £350 on it, which admittedly isn't "a lot". I'm finding lots of little niggles with it that are annoying, gears needed tuning, brake cables needed adjusting - dunno whether it's the bike, my load, or just my inexperience.
Should I really be needing to do all this at 300 miles?
Sounds good to me - wheels good for up to 160Kg
It would have to be a good one as I have got through a pair of RS10 and 11's I am 78Kgs bike 12Kgs so that leaves me 5-15Kg for rubbish. In my case both times the rim that has fractured.weight limits range from 95-110 kg for most manufacturers. you are over that.
You will need a good quality 36h handbuilt rear wheel. No 'factory' wheel will stay true for long unless you slim down to 100kg or less
With the right spacers 7sp cassettes fit, I used an 8sp cog at one point as a spacer.Waiting for another reply now but thinking about getting a wheel built and some new brakes, trouble is, I'm now looking at spending between £2-300 - would I not just be better off getting a new bike and getting a wheel to put on that?
The problem with my wheel is that it's a screw-on freewheel and I need to buy a new cassette as well. Cost on top of cost! I could take advantage of a 8/9/10 speed cassette, but then this means a new shifter as well... Could just stick with 7 (current wheel) but I dunno.
One option could be to get a wheel built with a 7 speed cassette and use the cheap wheel for a turbo trainer (I dont own one at the moment) as I've got spare tyres and tubes as well can just swap it out if I want a turbo session then.
Did go down halfords and looked at their Cyclocross Boardmans though, the CX Team (£900) was very nice, but no eyelets for a rear mudguard (despite having the fitting at the top for one) so that seems a bit daft to me - pity, it was a very nice bike!
It's been trued once by a wheel builder who says he undid all the spokes and tightened from scratch.
