We all did, except the usual culprit it seems.I know what you meant![]()
That's what I was intending to say @Justinslow , but I doubt I made it clear, I was able to hold the same cadence, but at a higher gear than with my other set up, applying the same pressure to the pedals as I normally would do.
Wouldn't more efficient bearings give you both of those things?Measured with a power meter?
The only way of noting this to the wheels, is if you had the same cadence, and the same power output, but went faster.
If you decide to attribute faster acceleration to the wheels, then coasting speed would be slower, or at least it would slow down faster. In fact, it would lose speed at the same rate as you gain the acceleration. You can't get quicker accelerating wheels, that also roll for longer.
I'm afraid I didn't weigh the wheels, but in handling both sets, while making the change over, the Pro-lites were considerably lighter compared to the original wheel set (Richey rims/ formula disc hubs) ... costs were as follows
Pro-Lite revo A21 wheel set : £315
x2 Continental Gatorskin 28's : £50
x5 Continental 42mm presta inner tubes (on offer) £26
TRP Spyre brakes (front and back) £115
Was it worth it? well IMHO to me yes, I really could feel the difference in both how the bike now handles and the ease in which it moves along, but I can't give a definite answer until I do a number of longer runs, which I hope to do in the next few weeks.
Norm
Culprits i would say.......but whats new with those pairWe all did, except the usual culprit it seems.
That's a bloody secret, just say nothing about the jet pack![]()
Well they may have helped wouldn't you agree?Yes, but wouldn't be measurable outside of a lab.
I purchased new wheels also recently. I did my 14 mile evening loop 3 minutes quicker first ride out with them too, or it could have been less wind, or that I am more rested, or that I had actually eaten well, or that I adjusted my seat, but those new wheels certainly made me 3 minutes quicker!![]()
You said "you can't get faster accelerating wheels...that also roll for longer". I happen to disagree on the bearings alone.Yes, but wouldn't be measurable outside of a lab.
I agree that there are other factors, but also believe that the wheels themselves could equally or more likely be the cause of your faster ride effect.
All things being equal, I guess so, based on either replacing the bearings or buying the same wheels brand new again. That's not usually how it happens though.A new identical bearing will give the same result as a whole new upgrade too, but then the benefit would still be negligible.
When I suggested using a powermeter to compare wheelsets on a separate thread about wheels I was told that was an unreliable test............Measured with a power meter?
Can't see how the difference is negligible. Quantifiably speaking, maybe it doesn't equate to huge differences on their own, but combinations of better kit do.
Why are we not all riding basic cheap bikes if there's no difference? Rhetorical question btw.
I replaced the chain on my Winter Defy 1. It had only done 1,200 miles, but wanted to maximise the cassette and chain rings. Noticed the benefit of the chain straight away. Far more direct in power transfer. It's how the bike feels that matters as much as real world speed or effort gains.
