2 more things came to light:
1: I seem to be missing a couple wheel bearings, 2 or so. I think I lost some from when I checked that area last time.
2: The threads where the qr axle goes through on one side the thread is longer, If I try to even it out the hub becomes loose.![]()
I think we need a pic.
Rather important, as you have already noticed, the wheel won't spin freely otherwise.So this is the side that has some bearing missing. I have another spare wheel which has bearing i could use. But I don't know how important are they for a bicycle
I actually found the other bearing so they both now have 9 eachRather important, as you have already noticed, the wheel won't spin freely otherwise.
Ideally you should take the cassette out, clean the cup properly, put in as many bearings as they will fit in the circumference, and then take one out. That will be the correct number of bearings. It would be a good idea to have a tray under the wheel while you do that, to catch any bearing that might fall.
I found the other bearings so they have now 9 each. They seem move easily out of its place. Should add grease so they stay in place?Shimano hubs run with 9 bearings - you are missing three on that side. This will cause lots of problems not least of which the wheel won't turn properly.
Edit to add: that should read 9 bearings per side.
You need grease for lubrication, it also helps to keep the bearing in place when you put the axle back in. Do you know how to ask the cones?I found the other bearings so they have now 9 each. They seem move easily out of its place. Should add grease so they stay in place?
It seems the wheel spins more free now but listen to the sound.
Tomorrow I will add grease and not sure about the cones.
View: https://twitter.com/Laurisss333/status/1296902358887211010
