Isidore Isou
Member
Hello everybody,
I can't fine tune my rear wheel hub in order to have a smooth rotation without any play.
With the wheel mounted on the frame, freehub removed:
- Wheel: Fulcrum Racing 7 LG CX / Campa style hub / sealed bearings.
- Here is a video where I try to explain this problem (I've also posted this on reddit):
- If I tighten the adjustment ring (1), even all the way, I can't remove all the play, and the wheel keeps spinning smoothly.
- Then if I tighten the adjustment ring locking screw (2), I have to tighten pretty hard and then I can remove any play, but the wheel no longer turns perfectly freely anymore, no pendulum motion like on the front wheel, and if I remove the wheel, the hub feels rough.
- Since the locking screw should only lock, not remove the play, I have a problem, but where?
- Here is a picture of the axle, there is some marks where the non drive side bearing sits, but I'm not sure why. The axle seems fine, not bend, but it's a bit hard to be sure:
- Also, some play appears very rapidly on this wheel, like after 50km. Everything seemed fine when I started my last ride, but at the end of it, there were side to side play. Because of that, I have to tighten the adjustment ring screw pretty hard to lock everything.
- It begins at the end of last summer, I noticed some play in my rear wheel hub, after 2000 km of road bike tour.
- Changed one bearing witch seemed rough, to an enduro bearing. The other bearing is perfectly fine when I turn it by hand.
- I've noticed that the freehub is not the problem, it's perfectly fine.
