slowmotion
Quite dreadful
- lost somewhere
If you want to get an accurate measure of circumference, ride tyres inflated to one's preferred pressure for a bit, and ride for a mile or two outside. The clever consumer electronic device will derive accurate speed from GPS and corresponding rotational speed from the 'speed sensor' on the rear hub or attached to the LH chain stay (+ magnet on a spoke) and auto-calibrate the actual (and accurate) effective wheel/tyre circumference. To find out that figure, go in to the Garmin's 'settings' to find out.
However this measurement is not useful, in this context. The speed displayed will be per GPS (unless disabled or in a tunnel) or if the bike is ridden on the turbo, speed = 0 and whatever's displayed as speed really doesn't matter.
Have you actually done this @slowmotion ? How confident are you that your result is accurate within a tolerance of (say) 1% (22mm)?
What did you do with the information?
Temperature change is going to have a negligible effect on tyre height (pressure increase is about 1psi every 3 degrees C) btw.
Have I done this?? Of course not! Why should I care about an accurate speed or distance?
