Bristolian
- Bristol, UK
I'm not sure this is the right place for this so MODS feel free to move it.
All of the wheel circumference charts I can find say that a 700 x 28c wheel and tyre should have a rolling circumference of 2136mm and that is what I had set in my Garmin. About a week ago I needed to change the battery in the speed sensor and since then my Edge 530 has taken to dropping the sensor data during a ride, which I find somewhat annoying. I read elsewhere that Garmin bike computers compare the speed readings from the on-bike sensor and that calculated from GPS and if there is a significant difference they stop reading the sensor data and default to the GPS speed. How much of a difference is needed to be considered "significant" appears to be a secret. Yesterday, after another frustrating ride with no speed displayed or recorded, I decided to check the figure in the Garmin and it was something quite a bit smaller than 2136 so I re-entered that but haven't had a chance to try it out yet.
Earlier this afternoon I decided to actually measure my rear wheel - I know, I need to get out more
To my surprise, the actual circumference is 2145mm which is pretty much what the charts say a 700 x 30c wheel and tyre should be (2146mm). I have checked this measurement several times (in several different ways) and get the same result each time (+/- 1mm) so I'm pretty sure it's correct. Is this unusual or not? Am I reading the charts incorrectly? Would a 0.4% speed error be enough to cause the Garmin to play up? Should I enter the actual circumference or leave it at the chart figure?
All comments and advice will be much appreciated
