What's Wrong With My Bike? Squeaking or Squealing Noises?
ron916
Hey guys.
I made a video of what my bike is doing. I am hoping someone will watch it and help me figure out how to solve the problem.
link
gbb
Peterborough
Does it feel smooth as you pedal ?
First port if call would be cranks and BB for me.
Make sure nothing is rubbing, chainrings, crank arms etc.
Does it have a sealed BB or is it an older style solid axle, bearings and adjustable cups ?
Either way, id squirt a bit of oil into the BB, turn the bike on its side and let it run down the side if the axle into the bearings, see if you can get it to quieten down. Its not a fix but can help you identify the problem area.
If that quietens it, new BB in all probability.
It could be pedal bearings but thats a heck of a noise for that.
  • Like
Reactions: C R
gbb
Peterborough
Also check the chain is routed correctly through the rear derailleur. Not the noise id expect if it was incorrect but its quick to check anyway.
  • Like
Reactions: C R
