Yes frame broke, new frame, so unmounting bottom bracket/crankset, decided to not risk the Octalink design flaw lack of press fit of left crank, reappearing again, a suddenly losening crank on a bad moment is a recipe for disaster.
Decided back to square taper.
- 47 mm chainline distance
- gear 47/16
- gear fixed so also uphill + headwind.
- heavy bike - heavy load
- resisting pedals to slow down so also opposite oriented force on cranks and their mounts
Something to take into acount, since for ex cranks at drive side have clockwise tensioning while nondriveside anticlockwise tensioning, and resisting a pedal is then losening direction instead of fastening direction. So tensioning enough from the beginning, don't rely on further tensioning by pedaling. It could be a forth and back until cranks pedal eye thread ruined, which may have been 1 cause of the breaks I suffered with the Stronglight cranks, the other cause these having less thread due to thinner. The less thread makes thread damage easier, and also losening easier. It all acts towards failure, adds up to achieve it, take away one element and it works for 1 but doesn't for another.
Which may make that yours run for you that many years/km but less for me.
And since lost material aggravates it, exponential factor, that less can be alot.
