Thank you,
@GuyBoden
Not sure I think they're right that one is better than the other. The UN-55 is no longer made: the UN-300 is its replacement. The UN-55 is more expensive because it's increasingly rare: their 'pricier is better' conclusion is flawed. Both have steel 'cups' to screw in. Both have 'one piece' bodies. "Bigger bearings"!? Sorry? Groupset alignment is an irrelevance, imo. Tourney has a square taper chainset: so it needs a ST BB.
From the link:
"A big question then remains, between the still readily available and newer BB-UN300, and the older tried-and-true BB-UN55, which of these two is better?
"There are a number of reasons when looking at a BB-UN55 vs BB-UN300 I’d pick the first one.
- The BB-UN55 has always been more expensive than the BB-UN300. And although there is no straight-up comparison on the internet between the two, an increase in price usually means that higher-quality materials are used. The one-piece body of the BB-UN55 and bigger bearings suggests just that.
- The BB-UN300 is offered within the current Shimano Tourney MTB groupset. This is the lowest-tier groupset that Shimano offers, further strengthening the assumption that indeed the BB-UN55 is a higher-quality build.
". . . . there’s really nothing wrong with what I consider to be one of the most failsafe bicycle parts ever to hit the market, square taper bottom brackets would need to go some day. . . . if you are looking for a solid option for your restoration project and you ask yourself which one is better between the BB-UN55 vs BB-UN300, I would always choose the BB-UN55."
Square taper BBs will not "go some day". They will be here forever (check back with me in 10 years). The author might "always choose a UN-55" but only because they have stash of 20 various spindle widths. Mere mortals will have to use what's being sold: UN-300 or another make (see up thread).
