What size valve stem do I need ? Please help fast
SteCenturion
I am your Father
Hi folks.
First time posting in this section & could do with your help as I have some tubes in my basket.
My wheels are Easton EA50 Aero (30mm), American Classic Aero 3 (34mm) & Easton EC70 SL (42mm) & I have 42mm & 60mm Conti tubes in my basket.
Question is this/these,
1. Will the 42mm valve Conti valve stems fit my EA50's &/or AC Aero 3's ?
2. Will the 60mm Conti valve stems fit my EC70 SL with 42mm depth ?
3. Anybody used bikediscount.de ? & if so had any probs ?
For 30mm you need at least 48mm valves. so the 60s will do the job for the 43mm rims
I tend to use 60mm by default. I don't have any rims which are deep enough to require anything longer, and 60mm doesn't cause any problems with even the 25mm section rims.
