+1... after my light fell off I drilled a hole through my clip and cable tied it on.
This is the big tip!
I use a small hole drilled in the clip and a section of fishing line looped over the fitting. This makes changing batteries easier
most saddle bags/packs have a sewn in loop to attached a light to.
The Topeak saddle bag has a little loop that most lights can fit to.
Some are very tight to fit, although i think thats a good thing.
You can see the lopp on this one.
Sorry guys - don't have a rack and not likely to be doing any touring in the short term. Pure road only for the time being.
Seat stay sounds a possible option but maybe the frame bag is the way to go...
I commute in all fairness though.I'm not keen on lights which are fitted to bags, helmets or jackets. They rarely seem to be "aimed" properly and are not as visible as an accurately fitted light.
LED rear lights are usualy directional and, for them to be as effective as possible, they need to be "aimed" at following drivers.
FWIW, I would be concerned about the flares if they can be seen from anywhere in front of the bike. On a dark night an oncoming driver could easily be confused if he sees a red light and your headlight. Confusing messages lead to accidents.
Can only be seen from the rear and side angle. They are designed very well and also your legs obscures them if fitted to seat stays.
