Andy in Germany
- Rottenburg am Neckar
Does it fit over the lip at the top of the bottom part of the fork, and is it missing a clip of some sort?
No. I get the impression the rubber has split.
I'm surprised its not anchored to something, if the rubber has split is it repairable? Or is it too much work?
Kubota compact tractor
That would be ideal ur we give the lads a spade each!!
Did you compact it down afterwards??
More work on the Thompson Capella frameset I bought, which has gained a pair of Dura-Ace brake calipers along with Mavic Exalith pads, as I'm going to use son no. 2's old Exalith race wheels for a bit.
Also this week I picked up a pair of Elite Vico Glam bottle cages in dark metallic blue via eBay. They were expensive but set the frame off nicely.
Finally this evening I put a new set of hoods onto a pair of Dura-Ace 9001 shifters I picked up. One I knew had a hood tear, but the other wasn't in a good state either. Fitting them wasn't easily as it's a very tight fit; they went on better with the bar clamp removed but one shifter now has my blood on it. All done, along with a clean of the shifters, and they're on the bars.
Photos shortly, but I'm now getting closer to the end. Only the really difficult bit to do; I'm using 3T Aeronova bars as we have a couple of spare pairs and from memory I'm aware they're a pain to fit cable outers through. Once the cabling's done it'll be a chain plus adjustments.
There wasn't a rush, since I can take my time and then take the Dawes Giro most-of-a-bike off the smart turbo to dismantle once finished, but SWMBO wants the dining room cleared. I've been doing the build inside rather than out in the conservatory workshop since a) it's been cold and b) I don't want the locals pinching my nice frame and components before it's all bolted down on the turbo. However, needs must ...
The Dawes Giro will then head off to be stored, doing a swap with my Raleigh, or stripped back to a frameset and sold. Still undecided there, although I've spent a lot more than planned on the Thompson build. It was supposed to be simply a frame swap and I've turned it into a full Dura-Ace 11-speed build, buying the groupset piecemeal.
I hope you haven't put Dura ace on a Dawes giro!🤣🤣🤣
