I had an Apollo bike from one of my young cousins to work on at the end of last week.  The brakes weren't working, the back wheel had a buckle, the rear derailleur had been bent and partially straightened and he wanted new handlebar grips fitted.
I started off servicing the wheel bearings where the bearing tracks were pretty good but the balls were dull and pitted so some new ones went in.  The brakes are basic cable discs and I was expecting to find worn out pads but they look new so just needed setting up properly.
I thought retruing the back wheel was going to be a simple job but annoyingly one of the spokes broke while doing it.  Fortunately I had one the correct length to hand so fitted that then detensioned the wheel and trued it from scratch, which I wish I'd done in the first place.
The rear derailleur was a bit of a mess but after dismantling it, cleaning everything, straightening the plates and replacing the cables it all works as it should.  That then showed that the front derailleur wasn't brilliant - the cage is pretty worn and wouldn't shift to the small ring without touching the tyre, then at the opposite end the chain was jamming most times when trying to shift up to the big ring.  I tried numerous different adjustments but in the end gave up and just bought a new one which works beautifully.
The grips were a bit long to go on with the grip shifters that are fitted but it was easy enough to trim them down and rearrange the controls.  Hopefully I shall have a happy client.
