Some fettling from a few days ago. As has been mentioned elsewhere,
@gavgav had a gear cable break recently which made his request for me to do a service rather more urgent.
First job was to get the broken end out which was easier said than done. After trying and failing I came back to it fresh the next day and with the use of a thin screwdriver and my special cable end recovery tool (a small hook made from a paperclip) it came out, which I was quite relieved about as the alternative according to the dealer manual would have involved unwrapping the bar tape then removing and partly dismantling the shifter.
The rest of the service was more straightforward. The rear pads will want replacing before the next service and fortunately it seems that the Shimano pads that Gav already has some spares of are compatible with the TRP Spyre brakes.
Servicing the hubs I found that the front one looked like new but my heart sank on seeing the discoloured grease in the rear. It turned out not to be as bad as it looked though with nicely run in bearing tracks and only needed new balls and fresh grease.
The chain was stretched so I've put on a new one but a test ride showed that it slips very occasionally under heavy load on the smallest sprocket, which is a little disappointing after only 1400 miles. Being so occasional, Gav is going to try it for a bit and see how it goes once the new chain has bedded in. I think there is a good chance it will be alright but I now have a cassette in stock in case I'm wrong.
