Juan Kog
permanently grumpy
Thanks for the warning, I didn’t bother with the angle grinder I just threw it in the scrap bin .Angle grinder and alloy don’t mix ...... be very careful .... you cant grow new fingers ...
I recently had a Steel crank extractor tool versus aluminium crank threads incident which didn't end well at all. Fortunately, along came Mr Grinder (if you know what I mean ) and off those pesky cranks came. It was on a SS bike so the replacement crank set wasn't that expensive and being a Steel frame helped too. Grinders are a brutal last resort but when used carefully can be a godsendThanks for the warning, I didn’t bother with the angle grinder I just threw it the scrap bin .
I fell into one of those "I think I will just change the brake cable" traps, on my oldest CAADX and ended up changing the Cassette, Large Chainring, Jockey Wheels, Chain, both Brake/Gear inner + outer cables, Cantilever Pad inserts, dismantling & regreasing the BB/Headset sealed bearings and ordering a small chainring and set of bolts to go with it.. It now runs silky smooth but 30mins into yesterdays ride I got a rear punctureI've needed to change the gear cable for a while, the changes have lost their crispness and the cable end has become frayed after I lost the end cap on a tour last year and I was unable to replace it before it started fraying. Now as much as I like SRAM and my Rival 1 groupset, the whole changing gear gable thing is just one monumental faff that involves stripping the bar tape off to get to the cable. However, being 1x, there's only one cable to replace. The original Kona bar tape is past it's best though, so all things considered it's actually two jobs for one.
So new Jagwire cable and one side re-taped with Cinneli Cork tape. Just need to clean the rubber brifter hood and re-tape the other side to match.
