Most of the day spent fettling the metal bike shed; finally put the dehumidifier in it. Definitely in need of it today with the roof dripping with condensation.
A hole was needed in the side for the outlet tube which took far longer than expected to create due to the battery powered drill deciding it needed charging and ultimately resort to a file due to hole size needed. An existing hole on the other side enlarged to take an extension cable, one from Screwfix with a nice weatherproof socket on the end and a hole drilled in the garden shed for the cable to access the mains socket in there.
Fitted a dehumidifier control unit between the extn lead and the dehumidifier itself which has a digital readout of just how wet it is and a cable senor which was fitted midway across the roof. 90% it said, target is 50% so electric company will be rubbing their hands
Holes in the shed painted with the correct paint for the shed and the hole to the garden shed a surround of sealant.
One problem created is that the road bike now has to lifted over the outlet tube and a drop fitted onto a bracket . To make it simpler have ordered a skateboard mini ramp so hopefully the bike can then be pushed in up and over the tube.
