- South Manchester
The Bianchi mtb doesnt shift very well between the two front rings. Theres some play in the mech which I suspect is the problem but I figured I would try and get it sat as close to the rings as possible first to rule that out. It's a real pain as the direct mount bolts are behind the chainring so the chainset has to come off before you adjust the mechIt makes it a bit more of a challenge to adjust it, largely guesswork and trial and error
Anyway, I got it as close as I dare. If it still doesnt shift properly I'll bite the bullet and order a new one
Your cage is bent. The top edge should be level (parallel) with the mech body (same applies on electric stuff) - it's been bashed/yanked.
The outer plate profile should follow the chainring
Unless you can get a new cage, that's a full front DI2 mech... £££££
