Take tension off the front cable, you may be able to do this by selecting the small ring then going for a 'trim click' if there is one or failing that back off the cable adjuster or the cable clamp.
Have a good look at how high the front mech is before loosening the bolt or clamp that retains the mech and then turn it so that the arms are parallel to the rings then tighten the bolt back up now check that the mech is at the same height as before then re-adjust the cable to where it was before.
The bold bits are the most important, the mech needs to sit at a certain height above the chainrings, there is a bit of tolerance (couple of mm) but outside of that it won't work properly so the trick is to turn it without changing the height hence taking the cable tension off so that it's not pulled lower down the seat tube.
Schwinn Twinn?Managed to get the stuck seat post out of the Schwinn tandem frame.
Achieved with copious amounts of release oil & a bloody big pair of grips
5 speed! Frame number dates it as a 1979 Chicago built modelSchwinn Twinn?
Single, 3 speed, or 7 speed?
Sturdy, albeit heavy bicycles. A fellow I work with grew up near the factory in Chicago.
Fine bike, one of the last years of the internally lugged frames. Heavy bikes, but built to last. I just saw a 10 speed Varsity the other day at our bike co-op, and it wasn't the only Schwinn from that era present at the co-op.5 speed! Frame number dates it as a 1979 Chicago built model
OK, that looks reasonably straightforward.Loosen the cable, loosen the clamp, turn the mech, tighten the clamp and lastly, re-tension the cable.
I'll probably stick some masking tape on the seat tube both above and below the mech clamp to make sure I have a good marker for the right height. It'll probably only want turning clockwise two or three mm, there or thereabouts.
With a front mech I normally set the height to the thickness of a 2 pence piece between the chainring and the mech
That's a tip worth bearing in mind.![]()
American penny, worthless for anything else. Does fine job of setting FD height.
I got them off with my long pedal Allen key thingy and
(1) neither of them were stuck
(2) I didn't chew up my knuckles on the chainring
