Some fettling for which money will change hands for me today. When one of
@gavgav's colleagues needed some work done on his bike my name got mentioned (being Cytech 2 certified) so I've ordered parts and set to it this morning.
When I saw the bike the other day at first glance it looked pretty good, being clean and shiny. A closer inspection showed that all three chainrings were worn out with the middle one on the verge of losing the remaining teeth altogether. Three sprockets on the cassette were in a bad way and the wheel rims had lost their wear lines a long time ago.
I've adjusted the headset (sealed bearings are smooth so adjustment was all that was needed), replaced the gear and brake cables (the LH gear cable was right on the verge of snapping inside the shifter), glued the loose shifter indicator lens back down, replaced wheels, brake blocks, chainrings, cassette, chain and derailleur pulleys, checked the pedals (also sealed units which are silky smooth so left those well alone), set up the gears and brakes.
All it needs now is a test ride which I would have done today if not for the 50-60mph gusts of wind recorded locally this afternoon.
Fairly happy with that lot.
