I had the day off work today
Once I had weeded and spread some compost over the newly seeded front lawn I set to work finishing the Stumpjumper upgrades. First task was to fit the new stem. It's 10mm shorter and 0 degrees rise rather than the 6 degrees of the original so the front end is slightly shorter and lower.
I removed the clamps from the shifter and dropper lever and fitted the Hope brackets that mount them directly to the brake levers. I then spent what seemed like hours fitting the brakes
I had to modify both post mount adapters to fit the larger hope calipers, including recessing both slightly to allow the pads to fully retract. Quite a lot of faff that could have been avoided by buying the hope adapters but I got them to fit regardless
I cut down both hoses and bled them through, I aim to bed them in tomorrow
While I was fettling I cut down the dropper and shifter cables to neaten it all up and get rid of a couple of big loops of cable under the BB
In all I guess I spent about 6 hours messing around in the garage today, bliss
I should point out I took those photos before I cut down the front brake hose and the two cables
