Pale Rider
Bike maintenance time breakdown:
60% cleaning
10% fettling
30% trying to get the shifter hood back on that thing that looks a bit like a camera hotshoe.
Camera hotshoe?
Way to go, granddad.
60% cleaning
10% fettling
If using SPD-SL shoes, have a listen to the shoe as you shake it back and fore in your hand. It’s a long short, but on my shoes there is a central threaded piece that slides centrally in a slot. Mine was loose and was gently sliding back and forth on every pedal stroke. I had searched the bike for everything possible and also regressed the clear bolts before finding this on second removal of the cleats. Likely not, but worth checking though.Lizard skinned my Cervelo as well - not sure about the lumpy nature of the wrap, but that's probably just my utter ineptitude.
Now I just have to find out what is going 'click' with every peddle revolution...
If not that, try gently spraying the pedal with GT85 or similar. That was another issue I found in hot weather like this.
Then start looking for random things like the trailing gear cable from the front mech hitting your shoe when in the inner chainring like my mates was.
It might take you a while to track it down though...
Er, some nice looking flaps you have there!![]()
That's a new one for me, sewing with a hammer......Haberdashery ... That's a word that you have never seen me post before!
Today's fettling was not one of my bikes, but my Endura baggy shorts. Several years ago (when my belly was several sizes larger than it is these days) the fastener on my shorts gave up under the strain. I have been relying on the belt and zip to hold the shorts closed and up since then.
Anyway, today I was walking past a(n?) haberdashery stall at Todmorden market and I spotted a kit which I could use to repair the shorts. £5.95 for 10 sets of 'snaps' so each use will cost less than 60p.
I set to work when I got in ...
The problem:
The solution:
Outer outer:
Inner outer: View attachment 417720
Outer inner:
Inner inner:
S(h)orted!:
As you can see, I did manage to put a small scratch on the front of the 'snap' (stud)!That's a new one for me, sewing with a hammer......![]()
The bike looks very tidy in the 'after' photo - have you got one taken 'before'?Drilled my brake levers and re routed the cables to go under the bar tape because dia compes idea of routing them was bloody stupid.
Much neater.
