Fifelad
- Carnock,Fife
My life is complete, tackled the potential horror of replacing the internal rear gear cable on the Cube, and indexed with minimum swearing, and nice new bar tape.
That sounds like my sort of fettling.I had a go at indexing the gears on the mongrel, which have been a bit chattery lately. It seemed to go very smoothly - suspiciously smoothly - on the workstand, so I'll be interested to get it out on the road again.
However, while I was close-up to the rear wheel I started cleaning the nooks and crannies, then decided to remove it from the bike and give it a good clean-up. Afterwards I couldn't get it to sit centrally and move through the gears, and eventually realised I'd loosened some of the nuts etc. on the threaded axle. Good opportunity to degrease and clean those before tightening up, I thought, until a ball bearing dropped out.
Rear wheel now at the LBS getting properly serviced.
It is keeping time with my quartz watch at the moment .
Looks good @DCLane, so a vote from me to keep it as it is. Though have to ask, is it a trick of the light and the two blue cables by the bars are the actually same shade? Or are they slightly different?
I would go for blue bar tape if you have it but black would work.They're very slightly different - but I'm hoping once bar tape is added it won't be obvious as I've run out of gear cable outer.
There's a good chance the bike'll be up for sale soon, so I want to keep costs to a minimum where possible.
I've been working on the Focus Culebro frameset 'with bits' that I picked up recently. Essentially it was a full bike minus wheels but having issues. This evening I've fitted a new rear gear cable outer in 3 parts, meaning that the gears now work since the original was split. 38mm semi-deep Merida wheels which match, new Ultegra chain and a cassette fitted leaving the bike looking like this:
It leaves me with a question for the CC folk: can you mix blue and black cable outers?
The previous owner had black brake outers and blue gear outers. I'd prefer not to change the brake ones ...
Oh, and I swapped the 138mm Paradigm saddle on my Wilier for a 128mm Paradigm as it's more comfortable. Note that this information, combined with the above reluctance to fit new cables, does not mean that I'm a tight ...
