the stupid one
- NWUK
Groan. I went out on the hardtail RockRider BigRR 5.1 a couple of days ago, and noticed that the brakes were a bit dodgy and the gears needed tweaking.
The weight, geometry and tube cross-section of the bike meant that the workstand wasn't very happy. The front derailleur was a real bugger, but I got there in the end. The rear derailleur just needed a bit of a twist of the barrel adjuster.
Meanwhile the rear brake seemed to have gone completely t*ts up. It was doing that annoying thing where it closes but then refuses to open. I adjusted the blocks, in case they were catching the tyre as well as the rim, but that made no difference. Sent some lube into both ends of the rear cable outer, which also made no difference. Then I had a lightbulb moment - surely the clamp on the workstand is interfering with the bare inner cable. What a dope . . . but it wasn't that either.
Finally I got to the front end, and the problem was an almost invisible deflection of the front outer as it left the barrel adjuster. With the merest touch the problem disappeared. Grrr. With a bit of loosening and tightening I think I've sorted it for the moment - worked OK over several pulls, then on a short testride. In fact the brakes are very effective now. The lad had a quick go and he was pleased with the brakes and gears, and he's hoping to do the Wirral Bikeathon on Sunday.
And after all that I got the junior B'Twin bike which the lad used to fit and gave it the same treatment. That was a lot more user-friendly. What a relief.
