ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
I have started putting my old Crud Roadracer mudguards on my singlespeed bike. As always, it is a fiddly process to get them not to rub when clearances are tight. I was getting a noise from the front guard once per revolution of the wheel. I thought that it was probably due to the wheel being out of true but that turned out not to be the case - non-true was in fact un-true!
The problem is due to a kink in the tyre. I have taken a couple of pictures which try to illustrate the defect. They are not that clear, but you can see that something is not quite right.
I have had that problem before and it turned out to be due to the tyre breaking apart from the inside. That's a scary problem, so I whipped the tyre off to check it from inside. I can't find any problem with it! I used a magnifying glass to get a really good look but couldn't see anything wrong; I ran my fingers round the inside but could not feel anything wrong.
The tyre looks like it is only about 40% worn so I want to carry on using it if possible so I have marked the tyre where the bulge is and will check it again after every ride now to make sure that it is not getting worse.
The Crud guard will stop me forgetting about the problem. It will start rubbing again if the bulge gets even slightly bigger.
I want to fit the rear guard but somehow I have lost 1 of the 2 mounts plus its 2 rubber o-rings. I could understand if I had mislaid 1 of the 3 parts but to lose all 3 makes me think that I have put them all down somewhere. I will be able to bodge a mount if I have to but it is annoying to have lost these parts. I must have another look in a minute.
