andytheflyer
- South Cheshire
Yeah, that's what all the advice says but I can't see evidence of it, nor a way to correct it.
https://www.cyclechat.net/threads/squealing-rear-break.181763/#post-3743189
IIRC, the leading end of the pad needs to touch the rim first, you can alter the angle of the pad with the rim by slackening the nut holding the pad, and rotating the pad slightly - there's a ball joint in the mounting post arrangement. Assuming you have V or cantilever brakes that is. Can't remember by how much the pad needs to be rotated, but try a thick bit of card at the trailing end of the pad to act as a spacer while you tighten the nut. Better bike mechanics than me will be along to correct me - but you get the idea. A bit of T&E will be required.
Some pads are noisier than others (IME) - I use KoolStop (Salmon or salmon/black mixed) and these are very quiet and the best I've ever used.
and I never use a pressure washer.
