What Have You Fettled Today?
arch684
I've been spending my evenings building a new wheel set. Ambitious, but I had nothing to lose. The rims on the old wheels both had nasty dinks on them, not my doing, but the spokes and hubs were of a good enough quality, that I wouldn't want them to go to waste. So after a good few hours surfing the net looking at wheel sets, and realising that I couldn't afford anything of equal quality, I started looking at rims. I found a pair of Exal LX17 rims, which seemed to have reasonable write ups, and also described as 'forgiving' for the novice, for a little over £20. So I dismantled the old wheels over last weekend and have spent the last couple of evenings re building onto the new rims. After a few false starts, trying to get the lacing and spacing right, I fitted the new builds last night and took them for a ride today. First impressions.....NICE !. Well worth the effort. The most difficult part of the process was getting the wheel round. I've got it to within a couple of mm on both of them. Getting them straight was easier, as well the dishing. I used my rim brake settings to adjust them to run straight and central, but keeping them round meant a little more ingenuity. I ended up stretching a loop of fishing line across the stays/forks, and moving it back and forth as required. If todays outing is anything to judge by, then I have a lightish, strongish, quality set of wheels that will do me for many miles. Plus I got a bit of an ego boost knowing that I had managed to complete a task that I had never tried before. Chuffed ^_^
well done and i bet you want to do it again
Wet ride home, bike not too dirty, but chain covered in crap from the cycle route. Poked crap out with an Allen key, wiped, wiped, lubed and wiped again. Was sounding like a popcorn machine tonight (fixed gear).
Psycolist
NINJA BYKALIST
North Essex
Fork fettling today.....received my new mtb Rockshox Sids yesterday. :hyper: Spending the afternoon fitting and tuning to my liking, Hopefully get out on them tomorrow before the rain sets in. And in reply to Arch, not straight away, but its certainly a job I would try again.
DCLane
Set up my 10 year-old's Felt F95 Junior race bike for the new season which for him starts on 7th March at York; new Pro-Lite A24's in 650c size, gears set for Under 12's.
We've got the bike down to 8.8kg with pedals which is about as light as it'll get; given Felt's 'official' weight was 8.6kg I'm presuming this was without pedals/tyres/etc. as we weighed it at 9.6kg on receipt.
Still probably needs new bar tape (mildew on white tape xx( ) and checking over properly. That'll be next week.
Gravity Aided
Land of Lincoln
Started work on different cantilever brakes for touring bike, new BB ordered and chain as well. Brakes were a tad rusty, so they are soaking in some vinegar for a few days. Trying to modernize a wee bit, and make as many fixtures Allen Bolts as possible, and replace and renovate most of the moving parts. But winter has been severely cold this month, so this, my expedition tourer project, and the indoor trainer have gotten the attention and the $$ this month.
DCLane
Did a number of things:
- Cleaned the mildew of my youngest's Felt road bike xx(
- Fitted a new SRAM 8-speed chain to the Ridgeback Platinum.
- Fitted a new Shimano Claris rear derailleur and new Shimano Tiagra rear brake caliper to the Carrera. That should hopefully solve both the gear-changing issue and stop the old Sora brake caliper reacting with the magnesium frame :eek:
Oh, and I re-built a rear derailleur using the Carrera's damaged Shimano 2300 one and bits from a Sora 3300 part I'd bought but wouldn't work properly. New skills are always helpful :okay:
Exile
Manchester
Had a spare few hours whilst the O/H was away, and decided to take the opportunity to get the CX bike back on the road. Full brake change (rotors, callipers, inners, outers) and took the cross levers off as I never use them and they were taking up valuable bar space. Changed over the wheels to the set without four broken spokes on the rear (that'll be my fettling for next weekend, perhaps), including swapping tyres and tubes, and finally re-wrapped the bars in fresh tape. Then it was just the simple matter of getting the brakes running smoothly (so much easier with the new mech/hydro hybrids) and giving the chain a clean and lube.
Quite chuffed with just how much I got sorted today, even if my first attempt at wrapping drop bars isn't the prettiest thing to look at.
Cp40Carl
Wirral, England
Put new brake blocks and brake cables on my Felt QX60. I got the bike 2nd hand and have been learning as I go with it. Just ordered new chain and gear cables so back to YouTube for me...
Got the whole lot off e-bay / Halfords clearance for about £20 (new and branded as well). New cassette after that. I can't seem to stop...
slowmotion
Quite dreadful
lost somewhere
I stuck my hand down the yard gulley that was clogged up with four years' worth of leaf debris from the gutters, squirted it down with a hose pipe, and went back inside with frostbite in my right hand. I thawed it out under the hot tap and managed to open a can of Belgium's finest.
uclown2002
Harrogate
Do you get the chance to ride a bike? You're always fettling!!
