I have
murdered my husband... fettled my husband's bike today.
New wheels because I was fed up of replacing the bearings in his rear hub (stock decathlon wheel) and this time around it needed cup & cones as well... So Shimano R501's were put on with a new SRAM PG-850 12-26 cassette and SRAM PC-850 chain. He needed new brake pads, 1 new brake shoe (one of them would not unscrew and the allen key just clicks in the nut to remove the old pad... will have to take a hacksaw to the screw later on) and both brake cables replacing. Regretfully he also needed new chainset which I didn't spot when I surveyed the damage to his bike prior to purchasing the parts needed, so has had to have the old outer and middle chainrings off my old cassette. Luckily the 8mm allen key that holds the crank arms on would not come off - I say luckily because I would have just swapped the chainset over and probably not have picked up on the fact that my old crank arm was 170mm and his is 175mm so he would have been left with odd length cranks - and that would have been very embarrassing!
Right up until the new chainset being required I had managed to keep the cost of the repairs to his bike down to a sensible £99... so cheaper than replacing the bike but...
From this (look at the middle chainring
to this on 2nd hand parts (not ideal - these were actually take off my bike as too worn
and the end result...
Anyone want to lay any bets that he actually notices a difference?
Nahhh... me neither.
