What Have You Fettled Today?
Ciar
London
Been on holiday so had the commuter bike into the LBS, it was shown some love upgraded the chain set which is now Deore, also swapped over to Marathon plus tyres from kenda happy mediums, it moves faster and the LBS convinced me these mudguards would rock, i must admit they don't rattle, all in all my cx has been transformed :smile:
Not today but last night but I put new wheels on the Bianchi last night; they claim to be 150g lighter than my old Khamsin's (not a mazzive amount but I didn't want to break the bank and a lot quieter ;) ) and are slightly more aero (35mm rims). Only tested them out on the rollers last night but they seemed good and without trying my rpm increased lets hope my speed increases also ;)
Chris S
Birmingham
I found a 22 tooth sturmey Archer sprocket in my toolbox and decided it to put it on my Batavus, just to see what difference it made to the gearing. These bikes actually have Sachs/SRAM 3-speed hubs but the sprockets are interchangeable.
I'm not surprised they're usually fitted with puncture-proof tyres, in order to get the rear wheel off you also have to undo the hub brake securing arm, two chain tugs and remove part of the chaincase. You're then faced with what is effectively an oil bath. These bikes might be designed to be ridden in your best clothes but you wouldn't want to change a rear tyre wearing them.
I got the replacement sprocket on OK but the wheel then fouled on the mudguard, as the chain now needed lenghtening. I'd had a misadventure with my ASDA chain-tool the previous week so I decided not to risk it and put the original sprocket back on.
On the plus side I found that my Batavus actually has a 19 tooth rear sprocket rathter than an 18 tooth one, so it wasn't as high-geared as I thought, There was hardly any wear on the sprocket so the bike seems to have spent most of its previous life in a shed and should be around for some time yet.
Linford
Adjusted my rear mech mid ride to pull the slack out of the cable as the index on the flight deck was out of sync with the cogs on the back end.
Gravity Aided
Land of Lincoln
Bought a Schwinn World Sport for a small bit of change, and will sell it on when the weather cools. Probably get new cables, a front wheel, and a brake lever. Hard to ride it otherwise, and does not impress the buyer well as it stands.
MrGrumpy
Huge Member
Fly Fifer
new SKF bearings fitted to the fixed rear wheel, that sorted out the wobble from it :smile: Only thing is I could not get a hold of 6000-2RS bearings only had ZZs at work, shall have to stick an order in :biggrin:
Cuchilo
Prize winning member X2
London
Moved the derailer over . Ive taken the bike back to the shop twice as the chain kept coming off and was told cable stretch , don't touch the gear set up . Ive set the gears up properly now so cable stretch shouldn't be a problem any more :rolleyes:
Leaway2
Lycrist
Had loud clicking when pedalling hard. Removed the bottom bracket and its absolutely shot. Its a wonder it moved at all. Looks like
RPM BB7420 BC 137 X 24T Its a bit corroded. The spindle measures 115 and is square taper.
It is from a specialized Secteur. Any suggestions for a replacement?
biggs682
Northamptonshire
managed to undo top headset locking nut after struggling for last couple of nights just the lower one to release now and then get the stem free ......... wish me luck
Cuchilo
London
When does fettling become OCD ? I'm just asking as I have started to spit on a tissue and clean like my mum used to do to my face :angry:
youngoldbloke
New chain on summer bike. Old one showing 0.75 on my chain checker. Took the opportunity to give the drive train a good clean. Chainrings off, cassette off, jockey wheels off. Some wear visible, but no problems with new chain/old cassette. Just needed to tweak the indexing a little when all back together.
biggs682
Northamptonshire
right both nuts have now been undone just the stem to free of now , it looks like somebody has used loctite !
