What Have You Fettled Today?
musa
Surrey
Took apart my bike and Built my new bike and started assembling the other bike which requires handlebars stem wheels
Couldn't progress due to no headset and no chain set yet to be delivered
Took my freehub apart again, to clean and grease the pawls. Tried an in between level of grease this time, I think I greased it too much the last time.
Supersuperleeds
Leicester
Saw a neighbour going out on her bike and called her back and pumped up her tyres for her this morning. Her tyres were that flat they didn't register any pressure on the track pump. Does that count as fettling?
Snapper88
Northampton
I cleaned my bike (just before it rained) reset my back wheel (was off center & could hear brake rubbing) & cleaned the gutters (again before it rained)
Shut Up Legs
Down Under Member
How to Make a Bicycle Silent.
1. If you suspect a bicycle part of making noise, then
  • disassemble it;
  • clean it;
  • regrease it; and then
  • reassemble it.
2. For anything else that won't shut up, refer to step 1.
I could see the storm clouds gathering on the horizon as I worked :laugh:
Deleted member 23692
MTB has had a shower (yes in the bathroom :smile:), then been dried off and had a liberal coating of 'GT85 splash on lotion' applied:laugh:
I wanted a bike ride with my OH this morning (bullying him into it at the moment), so his bike needed some fettling before we could go anywhere.
His chain was rusted in place it is so long since he last used the bike! Nothing was going to get that working again, so it was a case of grabbing the chain tool, removing the rusted chain, counting the links, adding 3 new pairs and a quick release to the chain hanging up in the kitchen (off his expedition bike - they just so happen to be the same type chain) and then checking his tyres - air added and we could get out for our ride.... 46km later and I now need to get him a new chain for his tourer which will be in use next month...
Overconfidentii Vulgaris
Fixed a slow puncture (down to 20 psi after 2 weeks since I last rode the bike) and also fitted a new chainring and chain to the Raleigh. I've changed to a 44 tooth big ring to give a few gear inches more at the top end.
Saluki
World class procrastinator
Not today but last night.
Took bars and shifters off my Defy 2, put on new bars (thanks @vickster) and Tiagra shifters purloined from hubbies winter bike. Took off the Sora derailleur and put on a Tiagra derailleur (no prizes for guessing where that came from). Fluffed up getting the chain back on so need to pop to LBS today for a new link and it will get done tonight. Must get some new bar tape. I like blue bar tape.
Over the next couple of days we will put the Sora stuff and my old handlebars on Hubbies winter hack aka his old Carerra Vanquish (the only Vanquishness about it is the frame nowadays). We are getting quite competant nowadays. We have a big book of cycle maintenance and if it all goes tits up, we have Howards around the corner.
cyberknight
CK#1`s front wheel kept catching on the brake blocks so i reset the blocks for better alignment, played with the spoke tension and finally took a hammer to the rim in a couple of spots as the wheel was fairly bent in places.
Good job i did as i noticed the washers with hooks that are supposed to hold the washer to the forks was actually lifting the wheel out of the drops outs slightly.
Runs a lot smoother now !
