I'm still going through my Spring spruce up of the Gravel bike. Today I was looking at the front brake that has a sticky master cylinder piston. Whilst I'm there it's also a good opportunity to renew the bar tape and replace the rubber hood that has seen better days.
Removing the brake lever and master cylinder cover is pretty easy and straightforward, the cylinder is proper gummed up though so I need to attach a bleed syringe to the bleed port and force it out. When it's out, I can then give it a good clean and then grease it up with SRAM Dot grease. It's quite common for these to gum up on gravel bikes due to the dust and dirt kicked up, unfortunately though SRAM refuse to sell them as a spare part so you need to be careful with them.
Rebuilding it all is a little more fiddly than disassembly, but before long I had the cylinder assembly back together. While the brake lever is off, it is a perfect opportunity to replace the rubber hood cover without having to disconnect the hydraulic hose. With that done, I replaced the lever, then reattached it the bars. Then I re-wrapped the bars is some new Cinelli Cork Tape.
Last week I'd done the same job on the other side whilst I'd been upgrading the shifter internals to 12 speed:
https://www.cyclechat.net/threads/c...-a-guide-to-sram-mullets.301861/#post-7376877)
So that's the bars and brake levers all completely overhauled as well as the drivetrain.
