sevenfourate
Devotee of OCD
- Lowestoft, Suffolk
They must have run out of bricks on the house opposite!
….suspect the colour difference is the Salt coming out: making some look ‘white’.
Well, I spoke to soon as was evident on yesterday's chain sucky and chain skippy ride. Last night I fitted a new cassette. Today I realigned the mech hanger, fitted a new long cage Claris mech that has been hanging around, which has thankfully fixed the chain skipping issue.FC M 732 chainring (32t) successfully bodged on to an old LX octalink Crankset, which involved a bit of filing. I decided to file the crank rather than the chainring.
I also reversed the B limit screw on the 105 rear mech and replaced the chain.
The old bike has taken a battering this winter and I suspect the rear dropouts and mech hanger need re-aligning, a job for another day
Fitted Santa's delivery of Colnago bar tape to the 'Colnago CX'. Nice feel, but it's a bit inflexible and the 'sticky tape' isn't that sticky, so it will unravel if you don't hold it in place when wrapping. There is a subtle 'stealth' print on the tape with the name, and the end caps have the cloverleaf logo, again 'stealthy'.
Yes I'm a tart.
I also fitted the SP41 Optislick gear cables to the commuter. It had picked up a fair bit of gunk in the rear mech loop.
One of the videos I found was from here by @RedRider from 2017 but the forum search don't wanna play ball, it's on youtube though just search Cloth Bar Tape Wrapping TipsWith the tape try using the 'Raleigh Wrap' method starting from the inside of the handlebars and finishing with the end plugs holding it tight.
More of a slight adjustment than a fettle but solved a problem. Ive been getting knee twinges recently and wondered if changing toe clip position might help. They were mounted perfectly central but i noticed one foot gravitated towards the crank and the other away indicating a lack of symmetry in my legs/knees/ankles. Shifted the clips about a centimetre [one in and one out] to allow for this. No more knee pain!Goes to show micro adjustments can make all the difference!
What does everyone else do that regularly removes chains to lube / wax / clean etc ?
