stuarttunstall
- Yorkshire Wolds
Oh yeah, take the orange label off (careful not to get greasy fingers in the rotor), you wouldn't wear clothes with the tags still on would you?![]()
Funny enough I keep thinking that lol
I live on the Yorkshire Wolds, at the top of Garrowby Hill...
When I did this it was not a major hill, it was just that it was very long downward slope...
The disc looks fine. Normally an overheated disc will turn all shades of blue and purple. If your brake still works as intended then just keep going.
Just make sure you don't drag the brake lightly for a whole descent as that's what sometimes causes issues. Saying that there were long periods of dragging my brake when I came down Snowdon and they still didn't go blue. That descent took about 20-25 minutes if I remember correctly.
On what basis, other than intuition, do you think that?I've no experience with disc brakes,
it will probably wear shiny again
I’m not even sure there’s anything that seems wrong with the rotors unless I am missing something. They will wear and also it you will have a film of brake pad residue on the rotor. It all helps with the breaking in process and ultimately keeps the brakes quiet and efficient. personally I would leave the pads alone and see how you go. I have ‘interfered’ too early in the past and made things worse.
The only thing I would say is find another position to put your front quick release lever. It sometimes doesn’t close properly if it against the fork or frame and it is also harder to get your fingers behind it to release it.
EDIT: To add, my Shimano rotors are shiny like yours in comparison to my Avid and TRP rotors which look more matt (my description) Seems normal.
