marinyork said:Mobi and willow, what are the teeth numbers on the front and rear?
Sheldon has a great page
http://sheldonbrown.com/gears/ unfortunately it doesn't cover 5s which is why I asked.
I think I'm ok really.Over The Hill said:I agree with earlier threads - do what is right for you. But I am not sure you are getting it from your last line.
fossyant said:Cadence of 60 or 70...noooooooo
Grinders !!!!![]()
Over The Hill said:Find steeper hills!
If you have a mountain bike then you will run out of gears on the road as they are often set with a fairly low range for - well mountains and off road stuff. Sort of like a tractor.
If you are on the road then get a bike for the road! You should then find you will not run out of gears until you are doing 40mph!
I run out of gears on my fold up and mountain bike on the road but hardly go into top gear on my racer.
punkypossum said:.. I would have thought the gears on a hybrid would be even more road friendly, or am I getting something wrong here?
marinyork said:I used to do this. I think you can get away with big gears if you live somewhere flat such as York, Guildford, Bristol, Cambridge where ever. As soon as you get somewhere slightly hilly it punishes your knees.
