Sittingduck
- Somewhere flat
On a compact, I use big ring and 3rd largest sprocket as my pulling away gear - then use middle of the cassette for most riding and only really engage the small chainring for serious climbing. People will say that 3rd largest sprocket is a bad chainline for the big ring but imho it doesn't give rub on a correctly adjusted front mech or wears the chain / cassette particularly quickly. Saves shifting the front a lot which you end up doing if you spend much time in the small ring on flat terrain (where you will rapidly run out of gears).
