tomb1960 said:
Is it when you hit an egde (eg a pothole) at speed and your poor inner tube is pinched momentarily against the rim?
Yes.
tomb1960 said:
I ask as I had two otherwise unexplained rear punctures on my run this morning (unexplained in that the tyre seemed totally un broached) one was definitely seconds after hitting a pothole at speed.
Also known as a snakebite (that's what I call them), the tell-tale sign of one is two slits parallel to each other running along the tube about a centimetre or so long and just under an inch apart, although the dimensions can obviously vary.
They are much more common when MTBing...I've only once had one on a road bike and that was when I was 'amber-gambling' on a downhill stretch of (typically bad) road.
tomb1960 said:
This did effect my enjoyment somewhat negatively.
Oh well we can't have that! The thing to do is recognise that it's inevitable, it happens to the best cyclists and the best bikes, there's not really
that much you can do about it, the way to minimise the 'negative effect on your enjoyment' as you so eloquently put it is just to feel slightly proud having successfully changed it.
tomb1960 said:
How are they best avoided, and are some brands of inner tube more prone to it than others?
Basically try to avoid potholes at speed, and have high pressure in tyres.
Other than that there isn't that much you can do.
All inner tubes are just rubber tubes, you can't really get a snakebite-proof tube. I think nokian do a downhill tube that is made of really thick rubber that is less susceptible to it but it weigh about a kilogram, costs about seven quid and is for 26" MTB wheels, I wouldn't even think it'd be worth it on my MTB and i get the odd snakebite now and again.
