ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
Like this...!
Excellent, thanks.Stop fiddling. It is square taper!
But, only your middle ring needs replacing.
This can work and I have used it as an emergency fix by the side of the road before, but it knackered both the bolts and the allen keys.
Over time there have been differences, but yours looks like the current shimano crank extractors.And are all crank extractors the same?
I looked on ebay and they have crank extractors for square taper.Over time there have been differences, but yours looks like the current shimano crank extractors.
But if your plan is now to just change the middle ring,, then you don't need to remove the cranks.
Not really. Press-on cranks come in three varieties I can think of. Square taper, Octalink and ISIS. The extractor for these three differs slightly, but the problem is usually solved with a little adapter that comes with the extractor. Octalink and ISIS have hollow spindles, so an extractor's contact point that works with square taper, will just disappear inside the hollow. A gadget (usually a little magnetic thingamabob) then fits over the end of the extractor's contact point and covers the hole in the spindle.And are all crank extractors the same?
Your crankset probably requires a 110mm BCD ring but well worth measuring (when you get access to the bike again) before purchase.Will any 5 bolt 36 tooth chainring fit?
I did the opposite (st to Octa), as an attempt to get rid of a rather big new chain tension variation that I didn't have with two older bikes equipped with Octalink v2 (Hollowtech) that wasn't an option now due to chainline.Stay away from Octalink, stick with square taper.
