For most of us, more like half that cost, or less.Considering that a new cassette and chain is in the region of £100+, I'd put your question in the 'silly' category.
I hadn't thought about watts but otherwise this exactly mirrors why I like to use Squirt.Ages; probably years rather than months. If cost saving is the sole objective then it's not overly appealing other than in the long term. If, on the other hand, cleanliness of everything matters to you, plus a marginal watt saving, then it's immediate. Personally, the fact that nothing ever has any 'oil' on it and every part of the bike is essentially clean at all times is very easily sufficient. Oh, and it takes me *less* time to attend to chain lubrication than it did when I used the wipe / lube method.
Apart from the "too much faff" aspect hot waxing would be out of the question in my house. My garage is 500 yards from the house and has no power. Chances of me getting my bike in the kitchen on a wet November evening to remove chain etc. are less than zero.
I feel either hot waxing or liquid wax give a significantly superior result to lubes.
Well you don't need to get your bike into the kitchen, you can remove the chain and just bring that into the kitchen
They get 10/10 for product naming from me. I was going to try Squirt but now I've changed my mind. There's no competition.
I started using it at the end of April and after a monsoon with a lot of flooding (including knee deep stuff) a few weeks back I reapplied it and I've been very happy with how its kept my chain good. I don't expect to reapply it that often again though; I've been using similar tungsten stuff on my good bike, its silent and things last twice as long, I'll leave that for months when its dry, but Squirt is supposed to be more robust sill. The tungsten stuff probably would have needed degreasing after the floods to remove surface rust, Squirt never :-)
@UphillSlowly in my experience yes, it will wash off but I would expect to get a full day's riding, dry the chain and reapply in the evening.
I use Muck Off wet chain lube all year
Hello again the forecast for where I will be cycling in a cohole of weeks time.is dreadful and I have started using Squirt. LBS suggests it washed out after a couple hours of heavy rain. Do you think I should revert to normal all weather stuff? Dolby want to stop and reapply in a thunderstorm to a wet chain on a mountain! Thanks
Forecasts for mountain areas are hardly ever reliable more than 3-5 days ahead. It could yet change.
But in very wet conditions, even the all-weather lubes will wash out after one decent length ride. You aren't going to have to reapply while actually out on the ride, unless it is MANY hours long.
This place rocks. It’s awesome you can have a month off coming here; and the very same lube thread is still at the top upon your return. Almost homely 🤣🤣
