turbocabbage
I am busy planning a round the world bike trip leaving this spring. I am planning on building a custom touring bike for this purpose, and I'm currently trying to decide what components to go for. So my three questions are:
Wheel Size: 26inch or 700c wheels?
There seems to be a consensus that 26inch wheels, tyres, tubes, spokes etc are much easier to buy in Asia and South America than 700c. From my own experience of third world countries, any spare bike parts will be hard to come by, regardless of wheel size and anything you can get will not be of high quality. But plenty of people seem to think that any that will be available will almost certainly be for 26 inch, and of course a substandard tyre or spoke which is compatible with your wheel is greatly preferable to waiting for a couple of weeks to have one shipped to you.
Regardless of what wheel size I go for, I will be putting on the fattest, beefiest touring tyres I can buy, and taking a spare pair of tyres, spare spokes and plenty of tubes. So, what do people reckon, are 26 inch parts so much more easily available in 3rd world countries that it would be sensible of me to with this wheel size in terms of spares? Bearing in mind that I'll have spare set of tyres with me.
On a related note, how likely is it that I will need to replace a rim? Bearing in mind I'll be riding on rough roads with a heavily laden bike for 10s of thousands of km. I've only ever broken rims before when they've been worn down by rim brakes, and I'd be running disc brakes, and also going for the strongest rims and fattest tyres I can get.
Frame: aluminium or steel?
I have an aluminium road frame already which I'm thinking of using. I've used it for touring before, but not on very rough roads. Would a steel frame cope with the extra weight and rough roads of touring better than an aluminium one, or does it not make much difference if I run fat high volume tyres? The other advantage I see to a steel frame is that steel is much easier (and therefore cheaper) to weld if it does get cracked.
Bearings for hubs, bottom brackets and headset: cup and cone or sealed cartridge?
Sealed cartridge bearings last longer without maintenance compared to cup and cone. However, it is simple to take apart a cup and cone and clean, regrease or replace the bearings, and the hub or bottom bracket will last a long time if this is done regularly. When a sealed cartridge bearing finally does where out, it the whole thing needs to be replaced. Which brings us back to the question of availability of spares.
Loose ball bearings and grease can be bought just about anywhere, they are not bicycle specific components. Whereas a bearing cartridge for a high end hub is specialist part which will probably be specific to the make of the hub. So I would obviously take spares. But I think it might be better to go for a cup and cone design, as I know I would be able to replace the bearings easily. Also I believe that sealed cartridge hubs need special tools to be taken out and replaced? And does anyone know if it is possible to put loose bearings in a sealed cartridge design hub as a temporary fix in an emergency?
Any input you can give is much appreciated!
